Define Tip-to-Tail Function and Display Attributes
From the Define
Tip-to-Tail panel, under Based on, select All,
Displayed or Selected for your
selection method.
- All
- Bases the definition on all curves in the session. Manual selection of curves is not permitted.
- Displayed
- Bases the definition only on the curves displayed in the window. You
can select curves manually. To remove a curve from the calculation
process, select the curve(s) from the Available curves list and
click the forward arrow,
, to move the
curve(s) to the Exclude column. - Selected
- Bases the definition only on the curves that you select from the list.
- Once you've chosen your selection method, the tip-to-tail function is calculated and displayed on the polar plot.
