Define Local Wrap Controls
Use the Wrap: Local tool to define local wrap size settings on selected surfaces.
Generally, local size definitions are required where you want to capture small features. During the wrapping process, selected surfaces will be refined locally.
- The wrapper will be able to preserve gaps between parts/surfaces if the defined size is 1/3 the gap size.
- As a rule of thumb, define the minimum size as 1/3 of the smallest feature you need to capture.
