Convert Geometry
Use the Convert tool to tessellate b-spline geometry and convert to discrete geometry.
You can convert to discrete geometry by faceting or remeshing. B-spline geometry will be removed after faceting, and all topology definitions, solids, surfaces, lines, points, IDs, and metadata will be retained. The workflow for discrete geometry will be the same as b-spline geometry. After converting the b-spline model to a discrete model, you will be able to use most tools with the same interactions.
Proper, finer sizes in tessellation will help to capture shape, and operations based on discrete geometry will be more robust.
