/RBE3
Block Format Keyword Defines the motion of a reference dependent node as the weighted average of the motions of sets of independent nodes.
| /RBE3/rbe3_ID | |||||||||
| rbe3_title | |||||||||
| Node_IDr | Trarotref | N_set | I_modif | ||||||
| WTi | Trarot_Mi | skew_IDi | grnd_IDi | ||||||
| rbe3_ID | Interpolation constraint
element identifier. (Integer, maximum 10 digits) |
| rbe3_title | Interpolation constraint
element title. (Character, maximum 100 characters) |
| Node_IDr | Reference (dependent) node
identifier. (Integer) |
| Trarotref | Code of DOF used for
reference (dependent) node.
(6 Booleans) Default (blank or 6 zeros), set on all DOF |
| N_set | Number of different
weighting factor and/or Trarot
sets. (Integer) |
| I_modif | Modification of weighting
factor flag. 4
Default (blank or zero), set to 1 (Integer) |
| WTi | Weighing factor of set
i. (Real) |
| Trarot_Mi | Independent nodes' code of
DOF used in interpolation of set i. (6 Booleans) Default (blank or 6 zeros), set on all DOF |
| skew_IDi | Local skew identifier of
set i. (Integer) |
| grnd_IDi | Node group defining
independent nodes of set
i. (Integer) |
Codes for Translation and Rotation: Trarotref and Trarot_Mi
| (1)-1 | (1)-2 | (1)-3 | (1)-4 | (1)-5 | (1)-6 | (1)-7 | (1)-8 | (1)-9 | (1)-10 |
| TX | TY | TZ |
| TX | Code for translation
TX.
(Boolean) |
| TY | Code for translation
TY.
(Boolean) |
| TZ | Code for translation
TZ.
(Boolean) |
Code for rotation
(Boolean) |
Code for rotation
(Boolean) |
Code for rotation
(Boolean) |
- This is equivalent to OptiStruct's RBE3, in which motion of a dependent node depends on the motion of a group of independent nodes with weighted average. It is similar to but more general than the kinematic condition interface TYPE2 (which is limited by one dependent node to one independent segment (3 nodes or 4 nodes) and for all translations and/or all rotation components), the dependent rotation is computed as a function of translation and rotation of independent nodes, if all DOF are set on in Trarot_Mi.
- It is recommended that for most applications only the translation components be used for Trarot_Mi (Spotflag =1 in /INTER/TYPE2). An exception is the case where the independent nodes are co-linear and some of the dependent rotation components can not be determined. In this case, some rotational component should also be set on.
- The absolute values of the weighting factors are not important; it is the relative values from different sets that are important since these will be normalized.
- All DOF of the dependent node should be
determinable.
If only translation components are used for Trarot_Mi and the independent nodes are quasi-collinear, numerical instability might occur in explicit analysis to avoid this; Radioss by default, will modify the input weighting factors slightly (I_modif = 1). To prevent this modification, set I_modif =2.
I_modif =3 will give an equivalent behavior as /INTER/TYPE2 with Spotflag =1.
- It is not recommended to define a hierarchy involving RBE3, with other constraint equation (kinematic conditions; however, this is permitted, if the hierarchy rule has been respected.
- Hierarchy rule involving
/INTER/TYPE2, /RBE2,
/RBE3, and /RBODY
is:
RBODY > RBE3 > RBE2 > INTERFACE TYPE2
