/MAT/LAW16 (GRAY)
Block Format Keyword This material law is based on Gray EOS and Johnson-Cook yield criteria.
| /MAT/LAW16/mat_ID or /MAT/GRAY/mat_ID | |||||||||
| mat_title | |||||||||
| E | ν | ||||||||
| a | b | n | |||||||
| P0 | C | S | 0 | αe | |||||
| AW | Pmin | E0 | |||||||
| c | m | Tmelt | Tmax | ||||||
| 0m | αm | e | ge | ||||||
| Tm0 | Vj | Vb | |||||||
| Eoh | Ay | ||||||||
| mat_ID | Material
identifier. (Integer, maximum 10 digits) |
| mat_title | Material
title. (Character, maximum 100 characters) |
| Initial
density. (Real) |
| Reference density used in
E.O.S (equation of state). Default = = (Real) |
| E | Young's
modulus. (Real) |
| ν | Poisson's
ratio. (Real) |
| a | Plasticity yield
stress. (Real) |
| b | Plasticity hardening
parameter. (Real) |
| n | Plasticity hardening
exponent. Default = 1.0001 (Real) |
| Failure plastic
strain. Default = 1030 (Real) |
| Plasticity maximum
stress. Default = 1030 (Real) |
| P0 | Initial
pressure. (Real) |
| C | Hugoniot
parameters. (Real) |
| S |
(Real) |
| 0 | Lattice
gamma. (Real) |
| e |
(Real) |
| AW | Atomic
weight. (Real) |
| Pmin | Pressure cutoff. Default = -1030 (Real) |
| E0 | Initial energy per unit
volume. (Real) |
| c | Strain rate coefficient.
(Real) |
| Reference strain rate
(time unit)-1. (Real) |
| m | Temperature
exponent. Default = 1.0 (Real) |
| Tmelt | Melting
temperature. Default = 1030 (Real) |
| Tmax | For T >
Tmax: m =1 is used. Default = 1030 (Real) |
| 0m | Melting gamma. Default = 0 (Real) |
| m |
Default = a (Real) |
| e | Electronic
gamma. Default = 2/3 (Real) |
| ge | Electronic energy
coefficient. Default = 0.0 (Real) |
| Entropy of
melting. Default = 9.637e+3 (Real) If blank or 0, default entropy of melting value is automatically translated to the working units. |
| Tm0 | Melting temperature
parameter. Default = 1.3 Tmelt (Real) |
| Vj | Volume where EOS are
joined. (Real) |
| Vb | Excluded volume for vapor
phase. Default = 0.5/r0 (Real) |
| Eoh | Energy at
V=V0,
T=300K,
P=0. Default = 0.0 (Real) |
| Ay | Coefficient of attractive
potential. (Real) |
| Join parameter. Default = 1.0 (Real) |
Example (Aluminum)
#RADIOSS STARTER
/MAT/LAW16/1
Aluminium - GRAY EOS (unit g_cm_mus)
# RHO_I RHO_0
2.7 0
# E Nu
0.71 .33
# a b n Eps_max sigmax
0.002 0.00144 0.62 0 0
# P0 C S Gamma_0 a_e
0 0.533 1.338 2.18 1.7
# AW P_min E0
26.98 -5e-3
# c eps_dot_0 m T_melt T_max
1 1E30
# Gamma_0m a_m Gamma_e g_e delta_S
2.18 1.7 0.6667 8.7e-9 9.637E5
# T_m0 V_j V_b
1220 0.47388 0.19025
# E_0h a_y Theta
0 47 1
#ENDDATA
Comment
- The correct moel units must
be defined in the /BEGIN card because the default value of
entropy of melting is calculated based on the unit system.
(1)
