/INIBRI/STRS_FGLO
Block Format Keyword Describes the initial state (full stress in global system, values for each integration point) for a brick.
| /INIBRI/STRS_FGLO/unit_ID | |||||||||
| brick_ID | Nb_integr | Isolnod | Isolid | nptr | npts | nptt |
| Eint | |||||||||
| Eint | |||||||||
| unit_ID | Unit Identifier (Integer, maximum 10 digits) |
| brick_ID | Element
identifier (Integer) |
| Nb_integr | Number of integration
points\ It corresponds to the property definition of this element. (Integer) |
| Isolnod | Number of nodes of solid
element (Integer) |
| Isolid | Solid elements
formulation It corresponds to the solid elements formulation of in property definition of this element. (Integer) |
| nptr | Number of integration
points in direction r. 4 (Integer) |
| npts | Number of integration
points in direction s. 4 (Integer) |
| nptt | Number of integration
points in direction t. 4 (Integer) |
| Plastic
strain (Real) |
| Stress in direction
1 (Real) |
| Stress in direction
2 (Real) |
| Stress in direction
3 (Real) |
| Shear stress in direction
12 (Real) |
23 (Real) |
31 (Real) |
| Eint | Internal energy of solid
element (Real) |
| Volumetric
mass (Real) |
- The initial state for brick may be defined by more than one block.
- If
Nb_integr > 1, the optional continuation lines must be
repeated for each integration point, if Keyword2 =
STRS_FGLO and 8-node solid element with 1 or 8
integration point.
Format Line 4; Format Line 5; Format Line 6
- If
Nb_integr > 1, the optional continuation lines have to be
STRS_FGLO and 16 or 20 node solid elements, 8 node HA8
elements, 8 node HSEPH elements, 6 node PA6 elements; 10 nodes tetrahedron or
Pentahedron 6 nodes.
Format Line 3; Format Line 4; Format Line 5
- nptr, npts and nptt are only useful in /PROP/TYPE22 (TSH_COMP).
- Using
/INIBRI/STRS_FGLO you are assuming there is no density of
the deformed elements. Before the first cycle Radioss will check consistency of the input stress tensor with material data
(stiffness and density).
(1) Where,- Density defined in the Starter file
- Density in the state file
If the stress is not fulfilled, then Radioss will correct the diagonal entry of the stress tensor:(2)
