/H3D/SOLID
Engine Keyword Generate H3D contour output results for /BRICK, /BRIC20, /TETRA4, /TETRA10 solid elements and /BRICK, /PENTA6, /SHEL16 thick shells.
/H3D/SOLID/Keyword3/Keyword4/Keyword5
#optional next line(s) that lists the parts to save results for.
part_ID1... part_IDN
/H3D/SOLID/TENS/STRESS/IR=1/IS=2/IT=1
/H3D/SOLID/TENS/STRESS/IR=ALL/IS=ALL/IT=ALL
/H3D/SOLID/ENER
1 55 75
- The syntax /H3D/ELEM/Keyword3/Keyword4/Keyword5 is also valid.
- When PART IDs are listed after the /H3D/SOLID line the specified results will only be output for those parts.
- Output can be a Scalar or Tensor as
defined in the following tables.
Table 1. Scalar Output Keyword3 Keyword4 Description AMS Elements using AMS timestep due to /DT/CST_AMS. DAM1, DAM2, DAM3 Principal damage values in local cracking skew direction 1, 2 or 3 for material LAW24 with /BRICK elements. DAMA - IR=
- i or ALL
- IS=
- j or ALL
- IT=
- k or ALL
Maximum of damage over time of all /FAIL criteria acting on one material. If Keyword4 is blank, the maximum integration point value in the element is output.
Refer to the specific /FAIL law used for how damage is calculated.
DENS Density DOMAIN SPMD domain number of an element. DT Element timestep ENER Specific energy density (internal energy divided by the element mass) EPSD Equivalent strain rate EPSP Plastic Strain FILL Filling percentage for /INIBRI/FILL FLAY Number of failed layers FLDF OUTER FLD damage factor indicator. 6 FLDZ OUTER FLD failure zone factor for the FLD failure model. - = 1
- Loose metal
- = 2
- High wrinkle
- = 3
- Compression
- = 4
- Safe
- = 5
- Marginal
- = 6
- Failure 6
HOURGLASS Hourglass energy MASS Element mass OFF Element status. Where the result output is:- = -1
- Element is not active (it is defined in an activated rigid body).
- = 0
- Deleted element.
- Between 0 and 1
- Under failure process.
- = 1
- Active element.
ORTHD - LAYER=
- i or ALL
- IR=
- i or ALL
- IS=
- j or ALL
- IT=
- k or ALL
Euler angles in degrees defining the rotation matrix to go from global reference system to orthotropic reference system. To request a specific angle use ORTHD/PSI, ORTHD/THETA, or ORTHD/PHI.
P Pressure SIGEQ Equivalent stress based on a material’s yield criteria. Some examples of yield criteria are von Mises, Hill or Barlat. SIGX, SIGY, SIGZ, SIGXY, SIGYZ, SIGZX Mean element stress in specified direction. TEMP Temperature TDEL Time at which element is deleted due to failure defined using /FAIL criterion. Failure criteria built in materials is ignored. USER - UVAR=
- i or ALL
- IR=
- i or ALL
- IS=
- j or ALL
- IT=
- k or ALL
User material (/MAT/USERij) law output for user defined variable i. Also, requests USR output for some Radioss material laws such as LAW59 or LAW70. USR1 output is requested using UVAR=1. For integration point results, use IR, IS and IT options. VDAM1 - IR=
- i or ALL
- IS=
- j or ALL
- IT=
- k or ALL
Value of damage factor D, for /FAIL/SNCONNECT. VDAM2 - IR=
- i or ALL
- IS=
- j or ALL
- IT=
- k or ALL
Value of damage surface for /FAIL/SNCONNECT. VDAM3 - IR=
- i or ALL
- IS=
- j or ALL
- IT=
- k or ALL
Value of rupture surface for /FAIL/SNCONNECT. VONM Mean element von Mises stress WPLA Plastic work for /MAT/LAW12 (3D_COMP) and /MAT/LAW25 (COMPSH) Table 2. Scalar ALE and CFD Output Keyword3 Keyword4 Description BFRAC Burn fraction (for JWL EOS: LAW5 and LAW51). BULK Artificial Viscosity. COLOR 1*vfrac1 + 2*vfrac2 + .... + last*vfracN (LAW51 and LAW151 only). K Specific for turbulent energy in CFD. MACH Mach number (/MAT/LAW151 only) MOM Cell momentum Density (MOM) for FVM with Interface TYPE22 for all components and magnitude. To request each separately use, MOMX, MOMY, MOMZ, MOMXY, MOMYZ, MOMXZ, |MOM|. SCHLIEREN Schlieren image (optical method widely used in CFD field). ALE material laws. SSP Sound speed. Only available with ALE material laws. TDET Detonation time output. TVIS Specific for turbulent viscosity in CFD. VEL Cell velocity for FVM with Interface TYPE22 for all components and magnitude. To request each separately use, VELX, VELY, VELZ, VELXY, VELYZ, VELXZ, |VEL|. VFRAC1,VFRAC2, VFRAC3,VFRAC4 Volumetric fractions (for ALE multi-material laws: LAW20, LAW37 and LAW51). VORT, VORTX, VORTY, VORTZ Vorticity for ALE material in resultant, X, Y, and Z components. VECT VEL Velocity vectors at finite volume cell centroids. CONT Contact force vectors at finite volume cell centroids. Table 3. Tensor Output Keyword3 Keyword4 Keyword5 Description TENS DAMA Cracks tensor at integration points for Material LAW24 only. If Keyword5 is blank, the mean value in the element is output.
EPSP - IR=
- i or ALL
- IS=
- j or ALL
- IT=
- k or ALL
Plastic strain tensor at integration points, only available for /MAT/LAW24 with Icpre=2. If Keyword5 is blank, the mean value element is output.
STRAIN - IR=
- i or ALL
- IS=
- j or ALL
- IT=
- k or ALL
Strain tensor at integration points. If Keyword5 is blank, the mean value in the element is output.
OUTER Membrane strain tensor on the outer surface of a solid or thick shell component. The membrane layer is automatically created, and the solid strain tensor is extrapolated to this surface. STRAIN_ENG -- Infinitesimal total strain. Only one tensor per element. STRESS - IR=
- i or ALL
- IS=
- j or ALL
- IT=
- k or ALL
Stress tensor at integration points. If Keyword5 is blank, the mean value in the element is output. OUTER Membrane stress tensor on the outer surface of a solid or thick shell component. The membrane layer is automatically created, and the solid stress tensor is extrapolated to this surface. - To request integration point results, use /IR=i/IS=j/IT=k notation where the options can be entered in any order.
