/DT/NODA/Keyword3/Iflag
Engine Keyword Activates the nodal time step control method with the option to apply mass scaling to increase a model’s time step.
- /DT/NODA/Keyword3/Iflag
- If Iflag=1, insert the next line
- grnd_ID
| Data | Description | SI Unit Example |
| Keyword3 | Time step control
type. 1
If Keyword3 is not specified, as in /DT/NODA/Iflag, then the computation will use the nodal time step and is not used. |
| Iflag | Node group flag.
| Scale factor on
critical nodal time step. Default = 0.9 |
| Minimum time step | ||
| grnd_ID | The nodal time step method is only applied to the nodes in this node group, read only if Iflag=1. |
- For all
Keyword3 options, the time step control will be activated
when the time step of the node controlling the time step of the simulation
becomes less than:
- Only one /DT/NODA/Keyword3 option can be used in a simulation.
- When using Nodal time step, the computation of each cycle is slightly more expensive but the time step can be higher especially for low quality meshes.
- When /DT/NODA/Iflag is used, the computation will use the nodal time step method and is not used.
- To determine how much mass will be added to a model, Radioss calculates a target time step for different amounts of percent mass increase and prints this information as a table and a graph in the Starter output file.
- /DT/NODA/Keyword3 is compatible with all options of /DT/Eltyp/Keyword3.
- /DT/NODA and /DT/NODA/CST* are compatible with /DT/INTER/AMS from version 2017.2.3.
- /DT/NODA/CTS* is
compatible with advanced mass scaling, /DT/AMS. If used with
/DT/AMS, AMS will be applied to the part group defined in
Starter /AMS card and /DT/NODA/CST* applied to
nodes not belonging to the AMS part group.For example:
- /DT/AMS/1
- Tol_AMS
- /DT/NODA/CST, /DT/NODA/CST1, /DT/NODA/CST2
This is even advised in order to minimize computing time in models where AMS only applies to selected parts.Note: It is pointless to use a higher time step in AMS than the one used in classic mass scaling since the smaller time step limits the performance.
