/ALESUB (Obsolete)
Engine Keyword Subcycling on Lagrangian parts.
/ALESUB
dummy
| Field | Content | SI Unit Example |
| Scale factor on time step for fluid parts | ||
| dummy | Dummy real variable (actually not used) |
- The must be less than or equal to 1.0. A value of 1.0 is recommended.
- If is equal to 1.0, the time step of fluid parts is equal to the critical time step of fluid.
