/ALE/GRID/DONEA
Block Format Keyword Velocity of a given grid node depends on velocity and displacements of neighboring grid nodes.
| /ALE/GRID/DONEA | |||||||||
| α | Fscalex | Fscaley | Fscalez | ||||||
| Vmin | |||||||||
| α | DONEA
coefficient Default = 0.0 (Real) |
| Grid velocity limitation
factor Default = 100 (Real) |
| Fscalex | X grid velocity scale
factor Default = 1.0 (Real) |
| Fscaley | Y grid velocity scale
| Fscalez | Z grid velocity scale
| Vmin | Elements with a volume
less than Vmin will
be deleted Default = -1030 (Real) |
- This option is available for 2D and 3D analysis.
- Further explanation about this formulation can be found in ALE Formulation in the Radioss Theory Manual.
