RESULTANT
I/O Options and Subcase Information Entry Enables the output of resultant forces and moments for internally generated sections.
RESULTANT (format_list, type) = option
| Argument | Option | Description |
| format | <OPTI, blank> |
| type | NOBOLT No default |
Enables output of resultants for user-defined sections but disables the output for cross-sections associated with pretension bolts. |
| option | <YES, NO, NONE, blank> |
- In case of transient analysis, OUTPUT, HGTRANS can be specified along with RESULTANT to obtain a session file (_tran.mvw file), that can be used for plotting the time histories in HyperGraph.
- Section resultant calculations are not available for transient subcases preloaded by a nonlinear static subcase, which may result in ERROR # 5837. In such cases, RESULTANT (OPTI) = NO should be used to disable their calculation and output.
- This output request is applicable to linear static and transient (direct and modal) analysis types.
