MATX28
Bulk Data Entry Defines additional material properties for Honeycomb material for geometric nonlinear analysis. This law is only applicable to solid elements.
| MATX28 | MID | ||||||||
| TIID11 | TIID22 | TIID33 | IFLAG1 | FSCAI11 | FSCAI22 | FSCAI33 | |||
| EPSFI11 | EPSFI22 | EPSFI33 | |||||||
| TIID12 | TIID23 | TIID31 | IFLAG2 | FSCAI12 | FSCAI23 | FSCAI31 | |||
| EPSFI12 | EPSFI23 | EPSFI31 |
| MAT9OR | 102 | 0.2 | 0.02 | 0.02 | 0.33 | 0.33 | 0.33 | 0.286E-7 | |
| 0.1 | 0.01 | 0.1 | |||||||
| MATX28 | 102 | ||||||||
| 11 | 22 | 33 | NEGSTR | 1.0 | 1.0 | 1.0 | |||
| 0 | 0 | 0 | |||||||
| 12 | 23 | 31 | NEGSTR | 1.0 | 1.0 | 1.0 | |||
| 0.0 | 0.0 | 0.0 |
| MID | Material ID of the associated MAT9OR. 1 No default (Integer > 0) |
| TIID11 | Identification number of a
TABLES1 that defines the
initial yield stress function in direction
11. No default (Integer > 0) |
| TIID22 | Identification number of a
22. No default (Integer > 0) |
| TIID33 | Identification number of a
33. No default (Integer > 0) |
| IFLAG1 | Strain formulation for yield functions 11, 22, and 33. 5
| FSCAI11 | Scale factor on initial yield stress function in
direction 11. Default = 1.0 (Real) |
| FSCAI22 | Scale factor on initial yield stress function in
direction 22. Default = 1.0 (Real) |
| FSCAI33 | Scale factor on initial yield stress function in
direction 33. Default = 1.0 (Real) |
| EPSFI11 | Initial failure strain under tension or
compression in direction 11. (Real) |
| EPSFI22 | Initial failure strain under tension or
compression in direction 22. (Real) |
| EPSFI33 | Initial failure strain under tension or
compression in direction 33. (Real) |
| TIID12 | Identification number of a
initial shear yield stress function in direction
12. No default (Integer > 0) |
| TIID23 | Identification number of a
23. No default (Integer > 0) |
| TIID31 | Identification number of a
31. No default (Integer > 0) |
| IFLAG2 | Strain formulation for yield functions 12, 23, and 31.
| FSCAI12 | Scale factor on initial shear yield stress
function in direction 12. Default = 1.0 (Real) |
| FSCAI23 | Scale factor on initial shear yield stress
function in direction 23. Default = 1.0 (Real) |
| FSCAI31 | Scale factor on initial shear yield stress
function in direction 31. Default = 1.0 (Real) |
| EPSFI12 | Initial failure strain under tension or
compression in direction 12. (Real) |
| EPSFI23 | Initial failure strain under tension or
compression in direction 23. (Real) |
| EPSFI31 | Initial failure strain under tension or
compression in direction 31. (Real) |
- The material identification number must be that of an existing MAT9OR Bulk Data Entry. Only one MATX28 material extension can be associated with a particular MAT9OR.
- MATX28 is only applied in geometric nonlinear analysis subcases which are defined by ANALYSIS = EXPDYN. It is ignored for all other subcases.
- This law is compatible with 10 node tetrahedron elements, and it is compatible with ISOLID = 1, 2, or 12 on PSOLIDX card.
- This law is not compatible with IFRAME = OFF, if it is referenced by the PSOLIDX card.
- When switching from a volumetric strain formulation to a strain formulation, IFLAGi = NEGSTR allows the same function definition to be retained.
- If one of the failure or shear failure strains is reached, the element is deleted.
- Transition strains define transition from initial yield stress function to residual yield stress function.
- If one of the transition or shear transition strains is reached, the element has yield stress described by residual functions in each direction. Transition is applied to the neighboring elements.
- This card is represented as an extension to a MAT9OR material in HyperMesh.
