FLSPOUT
I/O Options and Subcase Information Entry The FLSPOUT command can be used in the I/O Options section to control output of modal participation factors for coupled fluid-structure models.
FLSPOUT(argument = option, argument = option, ...)
| Argument | Options | Description |
| FLUIDMP | <ALL, NONE> | Requests fluid participation calculation of fluid response on
selected fluid points.
| GRIDFMP | <SID> No default |
Requests inclusion or exclusion of specific fluid grids to be used
in all the requested types of participation calculations.
| FEPS | <Real> Default = 1.0e-11 |
Filter Threshold for fluid participation. |
| ARF | <Real> Default = 1.0e-11 |
Acceptance ratio for fluid participation. |
| STRUCTMP | <ALL, NONE> | Requests structural, load, and panel participation calculations on
the selected fluid points.
| PANELMP | <ALL> | Requests inclusion or exclusion of panel participation calculations
on the selected fluid points.
| SEPS | <Real> Default = 1.0e-11 |
Filter Threshold for structural participation. |
| ARS | <Real> Default = 1.0e-11 |
Acceptance ratio for structural participation. |
| PSORT | <ABSOLUTE> | Requests type of sort.
- GRIDFMP is required for all FLSPOUT statements.
- FLUIDMP and STRUCTMP are required when PANELMP is defined.
- The output file name for modal participation is *.modal.
