udfGetElmNElemNodes()
Return the number of element nodes for the element set.
nElemNodes = udfGetElmNElemNodes( udfHd ) ;
User Defined Element
- udfHd
- The opaque handle (pointer) which was passed to the user function.
Return Value
- nElemNodes (integer)
- Number of element nodes in the element set.
Integer nElemNodes ;
nElemNodes = udfGetElmNElemNodes( udfHd ) ;Errors
- This routine expects a valid udfHd.
- This routine may only be called within a Body Force, Material Model or Component Model user function.
