PutPar()
Put a parameter of the defined types in the data base.
Usage
PutPar( path, par,
value, parType = None,
clobber = True, **opts )Parameters
- path (string)
- Data base path of the node containing the parameter.
- par (string)
- Parameter name.
- value (depends on par type)
- The parameter value.
- parType (data base defined type ((boolean), (integer), and so on)
- The parameter type.
- clobber (boolean)
- The parameter value will be overwritten if clobber is true.
- **opts (list)
- List of options.
Return Value
None
Error
The parameter must be in accordance with parType.
gNode = ROOT + RS + 'GLOBAL_MESH_ATTRIBUTES'
childPars = GetPars( gNode )
pVals = {}
for cPar in childPars:
pType = GetParType( cPar, gNode )
pVal = GetPar( gNode,cPar, pType )
pVals[cPar]= ( pType, pVal )
PutPar( gNode, cPar, pVal, pType, True )
