MenuTab()
Display a tab menu in the panel window.
Usage
MenuTab( tabs, node, par,
redraw=False, default=None )Parameters
- tabs (tuple of strings)
- A set of (label, value) pairs of valid values. Label is shown on tab widget and value is stored in the data base.
- node (string)
- Data base path of the node containing the parameter.
- par (string)
- Parameter name. The value of the menu is extracted from this parameter under the above node, and upon change by you, the value is deposited therein.
- redraw (boolean)
- Flag specifying whether to redraw the panel when you change the value. This allows inclusion of complex menus that dynamically depend on the value of this menu.
- default (string)
- Default value. If the data base does not contain the parameter given by the node and par arguments, it is first initialized to this value.
Return Value
None
- The parameter in the data base must be one of the defined tab names.
- The parameter must exist in the data base or the default must not be None.
nodeBfs = ROOT + RS + 'BODY_FORCE' + RS + item.name
MenuTab( tabs = ( ( 'Gravity','gravity'),
( 'Heat Source','heat source'),
( 'Species Source','species source')),
node = nodeBfs,
par = 'tab',
redraw = True,
default= 'gravity' )
