FWH_OUTPUT
Specifies output parameters for the Ffowcs-Williams Hawkings (FWH) method that is used by the AcuFwh post processing program to propagate acoustic sources to far field locations.
AcuSolve Command
FWH_OUTPUT{parameters...}
Qualifier
None.
- reference_density or ref_dens (real) [=1.225]
- Reference density. Required to compute the output quantities.
- reference_pressure or ref_pres (real) [=0]
- Reference pressure. Required to compute the output quantities.
- reference_sound_speed or sound (real) [=330]
- Reference sound speed. Required to compute the output quantities.
- source_output_frequency or out_freq (integer) >=0 [=0]
- Time step frequency at which to output FWH data. If zero, this option is ignored.
- source_output_time_interval or out_intv (real) >=0 [=0]
- Time frequency at which to output the FWH data. If zero, this option is ignored.
- num_saved_states or save (integer) >=0 [=0]
- Number of FWH data files to keep. If zero, all are kept.
FWH_OUTPUT{
reference_density = 1.225
reference_pressure = 0
reference_sound_speed = 330
source_output_frequency = 1
source_output_time_interval = 0
num_saved_states = 0
}The parameters reference_density, reference_pressure and reference_sound_speed provide the required data for the computation of the output fields. An AcuSolve input file should only contain one FWH_OUTPUT command.
