plt3DIPlot GetCurvePicking
Gets whether the client wishes to receive curve-picking information.
plt3DIPlot_handle GetCurvePicking
HyperWorks Tcl Query
The default behavior when a waterfall is picked with the mouse is to report the varname of the waterfall. If you want to know which slice (curve) was picked, you must enable curve picking (a similar principle applies with curve groups).
Returns true or false.
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetCurvePickingErrors
Success (0) or an error code.
