hgtrans config GetChannelSelected
Gets whether a data channel is marked for translation.
hgtrans config GetChannelSelected subcase, datatype, request, component
HyperGraphTrans Tcl Get
This command gets whether a data channel is currently marked for translation (true or false).
- subcase
- The name of the subcase from which to read.
- datatype
- The name of the datatype from which to read.
- request
- The name of the request from which to read.
- component
- The name of the component from which to read.
hgtrans control SetFile “columns.dat”
hgtrans control SetOutputFile “columns.abf”
hgtrans config SetChannelSelected “” “Unknown” “Res. ang acc (rad/s**2)” “column 2”
hgtrans config GetChannelSelected “” “Unknown” “Res. ang acc (rad/s**2)” “column 2”Error
None.
Keywords
get channel selection
