Update Result Files
Do one of the following:
- From the Results toolbar, click Derived Load
Steps
. - Select Create > Derived Load Steps from the Results menu.
- Right-click in the Results Browser and select Create > Derived Load Case then a load case type.
The Create/Edit Derived Load Case dialog is displayed. - From the Results toolbar, click Derived Load
Steps
Click the Result Files button.
The Update Result Files dialog is displayed.Note: All of the result files that are currently loaded are displayed in the Result file list.
- Use the Add result file browser button to select a result file (or multiple files) containing the loadsteps of interest from the Select Result File dialog.
Click Open to add the selected file to the Result file
list and also load the file into the current session.
The full path and file names are displayed in the Update Result Files dialog.Restriction: When adding new result files into the current session, only similar file types are allowed. For example, combining Nastran result files and LS-DYNA result files is not currently allowed.
To remove a result file, select a file (or multiple files) from the list and
click the Remove Result button.
Note: The Remove Result option is also available by right-clicking on a row within the Results file list.
Click Close to apply the changes and exit the
dialog.
Once the Update Result Files dialog is closed, the loadstep list will automatically refresh and display any changes that were made.
