Keyboard Shortcuts
Default keyboard shortcuts.
| Press | To do this |
| ←↑→↓ | Rotate the model by increments. |
Zoom in/out on the model by increments. Note that "+" is actually Shift = on the main keyboard, and simply + on the numeric keyboard. |
| E | Turn on/off edge lines. |
| F | Fill/Fit the model to the window. |
| H+left mouse button | Hide/turn off components. |
| I | Turn on/off Isolate/Isolate Only for the browser. |
| L | Turn on/off feature lines. |
| M | Turn on/off mesh lines. |
| S | Turn on/off the Selector for the browser. |
| T | Turn components to transparent. |
| U | Turn on/off Show/Hide for the browser. |
| Insert | Start the animation. |
| Delete | Stop the animation. |
| Home | Go to first step of the animation. |
| End | Go to the last frame of the animation. |
| Page Up | Move to the next frame of the animation. |
| Page Down | Move to the previous frame of the animation. |
| Ctrl+left/right arrow | Activate or deactivate the visibility of each model when two or more models are loaded. |
| Ctrl+X | Cut the active model in the graphics area (allowing it to be pasted into a different window). |
| Ctrl+C | Copy the active model in the graphics area (allowing it to be pasted into multiple windows). |
| Ctrl+V | Paste the cut or copied model into the active window. |
Secondary Menu
| Key | Function key only | plus Shift key | plus Ctrl key |
| F1 | online help | prev page | print land |
| F2 | -- | next page | print land file |
| F3 | -- | add page | print portrait |
| F4 | -- | expand window | print port file |
| F5 | -- | browser | png of page |
| F6 | -- | full screen | png of window |
| F7 | -- | less windows | avi full page |
| F8 | -- | more windows | avi box selected |
| F9 | -- | new session | h3d |
| F10 | alt key | alt key | alt key |
| F11 | -- | open session | -- |
| F12 | save as | -- | -- |
