Select a Projection Rule
Open the Iso panel in the following ways:
- From the Results toolbar, click Iso
. - Select Plot > Iso from the Results menu.
From the Iso panel, click the Projection Rules
button.
The Projection Rule dialog is displayed.
Select the primary and secondary axes from either the global or user-defined
system (selected for Resolved in).
When the primary axis is perpendicular to the shell plane, the secondary axis is used.See the Projection Rule topic for additional information.
