HS-1810: Post Process with HyperStudy
Learn how to create various approaches (Design of Experiment, Approximation, Optimization, Stochastic) and explore a variety of tools and post processing methods offered by HyperStudy.
Run Fractional Factorial DOE
Add a DOE.
- In the Explorer, right-click and select Add from the context menu.
- In the Add dialog, select DOE and click OK.
Define specifications.
Evaluate tasks.
- Go to the step.
- Click Evaluate Tasks.
- While the DOE is in progress, click the Tasks tab to view the feedback on the results of the evaluation.
- During the execution of the DOE, you can monitor the evaluation of the 16 runs in either the Evolution Plot or Evolution Data tabs.
Post process results.
Run Hammersley DOE
Add a DOE.
- Go to the step.
- In the work area, set the Mode to Hammersley.
- In the Settings tab, change the Number of Runs to 50.
- Click Apply.
Evaluate tasks.
- Go to the step.
Run Latin HyperCube DOE
Add a DOE.
- Go to the step.
- In the work area, set the Mode to Latin HyperCube.
- In the Settings tab, change the Number of Runs to 15.
- Click Apply.
Evaluate tasks.
- Go to the step.
