Write Solver Scripts
Solver scripts can be written in any language, and the contents can be as simple as a single line or a detailed set of commands. This generality is intentional so HyperStudy remains flexible enough to be wrapped around any non-interactive process.
- For each run, HyperStudy creates a separate run folder. In the case of multiple models, a separate model folder is also created. These folders are called Study Run folders.
- For each run, HyperStudy writes the solver input file to the Study Run folder.
- If any other files need to reside in the Study Run folder, they will need to be copied. For example, Radioss needs a starter file and an engine file to reside in the Study Run folder. A file can be copied from the study directory by adding its name to the solver input file. Separate names in the solver input file with a semi-colon.
- In order for HyperStudy to execute properly, verify that the solver returns control back to HyperStudy only after the execution is finished. Otherwise, HyperStudy will attempt to extract results before all files are finished writing and the study will fail. To avoid this, the solver should be run in interactive mode if possible. Otherwise, you will need to include a wait command in your batch file. Refer to Table 1 for solver wait command examples.
- In a study that uses more than one model, the models are executed in a sequence determined by HyperStudy. To control the sequence of runs, specify the priority option for the model. The results are extracted after the solvers have finished, or earlier depending on any model dependencies.
- A failure during the script execution can be noted by creating a file titled task__exe_err.txt. If this file is present in the run directory, HyperStudy will detect the execution as a failure. A similar error file can be created for other task failures: write (task__wri_err.txt), extraction (task__ext_err.txt) and purge (task__pur_err.txt).
| Solver | Wait Command |
| Abaqus | <PATH>/abaqus.exe job=jobname.inp |
| PBS | #PBS -W block=true |
| OptiStruct | -nobg |
Access Process Environment Variables
View a list of process environment variables set by HyperStudy, which can be useful when writing solver scripts.
- In the Message Log window, right-click and select from the context menu.
- Evaluate any approach.
The values of the environment variables for the current study approach will be displayed in the Message Log window.
Common CAE Solver Script Inline Commands
Solver script inline commands commonly used in HyperStudy.
Abaqus
$filebasename.- Windows
<PATH>/abaqus.exe job=%1 interactive- Linux
<PATH>/abaqus.exe job=$1 interactive
ANSYS
- Windows
<PATH>/ansysXXX.exe -b -i %1- Linux
<PATH>/ansysXXX.exe -b -i $1
Compose/OML
- Windows
<PATH>/hwx/Compose_batch.bat –f %1- Linux
<PATH>/Compose_Batch –f $1
LS-DYNA
- Windows
<PATH>/dyna.exe i=%1- Linux
<PATH>/dyna.exe i=$1
OptiStruct
- Windows
<PATH>/optistruct.bat %1- Linux
<PATH>/optistruct.bat $1
Example Solver Script Files Run Locally
Direct Call to an Executable
[Command] [ Arguments]“C:\Program Files\Altair\12.0.110\hwsolvers\scripts\optistruct.bat” test.fem –ncpu 4The
[Command] is “C:\Program
Files\Altair\14.0.120\hwsolvers\scripts\optistruct.bat”, and
[Arguments] is test.fem –ncpu 4. The command
is stored in HyperStudy as the solver execution script, and the
solver input arguments entry would take the text test.fem –ncpu
4.$file, which in turn can be accessed in the solver input
arguments, letting HyperStudy substitute this entry for you. In
this case the solver input arguments would take the form $file –ncpu
4.Basic Solver Script with Arguments (System Native)
“C:\Program
Files\Altair\14.0.110\hwsolvers\scripts\optistruct.bat” %1 –ncpu 4 –core
inThe
syntax %1 is a substitution of the first argument to this script,
which should be the input file. The argument %2 would be second
argument, and so on. This batch file can be registered as the solver script, and can
have the solver input arguments as $file.$n to access the nth argument.Basic Solver Script with Arguments (Python)
# import statements
import os
import subprocess
import sys
f = open('logFile.txt', 'w')
#set path to file
file_exe = 'C:/Program Files/Altair/14.0/hwsolvers/scripts/optistruct.bat'
#set arguments
file_args = sys.argv[1] + ' -ncpu 4' + ' -core in'
#correct the path for the operating system, concatenate, and execute
file_exe = os.path.normpath(file_exe)
lstCommands = [file_exe, file_args]
f.write('Running the command:\n' + ' '.join(lstCommands) + '\n')
p1 = subprocess.call(' '.join(lstCommands), stdout=subprocess.PIPE , stderr=subprocess.PIPE)
#write output and close
f.write('\nStandard out:' + '\n' + p1.communicate()[0] + '\n')
f.write('\nStandard error:' + '\n' + p1.communicate()[1] + '\n')
f.close()Script with Simple Logic
# import statements
import os
import subprocess
import sys
import shutil
#set path to files
file_to_copy = 'C:/Users/jmpajot/Documents/HMath_solutions/HST/documentation_changes/solver_script/target.txt'
#set arguments
#copy the file
f.write('\nCopying the file: ' + file_to_copy + '\n')
shutil.copy(os.path.normpath(file_to_copy),os.getcwd())
#remove the file if it exists
if os.path.isfile(sys.argv[2]):
f.write('\nRemoving the file: ' + sys.argv[2] + '\n')
os.remove(sys.argv[2])
f.close()Script with Environment Variables
# import statements
import os
import subprocess
import sys
import shutil
import time
#length of sleep command (seconds)
time_to_sleep = 1
time_out = 10
#set path to files
file_to_copy = 'target.txt'
#set arguments
#copy the file
file_to_copy = os.path.join(os.getenv('HST_STUDY_PATH'),'_usr',file_to_copy)
if os.path.exists(sys.argv[2]):
f.close()Waiting for an Output File
While most commands wait until they are completed to give control back to the script, some commands return control immediately. This is common, for example, with queuing systems. In this case, additional logic is required in the script to make the script wait before moving onto the next steps. One solution to this problem is to wait for a particular file that only exists when the process in complete.
# import statements
import os
import subprocess
import sys
import shutil
import time
time_to_sleep = 1
time_out = 10
#set path to files
#set arguments
#copy the file
p1 = subprocess.Popen(' '.join(lstCommands), stdout=subprocess.PIPE , stderr=subprocess.PIPE)
#wait for the file to appear
init_time = time.time()
while not os.path.exists(sys.argv[2]):
f.write('\n ... Waiting for file to appear: ' + sys.argv[2] + '\n')
time.sleep(time_to_sleep)
time_delta = time.time() - init_time
if time_delta > time_out:
f2 = open('task__exe_err.txt', 'w')
f2.write('Time of waiting for ' + sys.argv[2])
f2.close()
break
f.close()Example Solver Scripts Run on Distributed Machines
Run Solvers Using a Queuing System on Unix
This example script runs a solver using a queuing system on Unix.
The sample file is set up for running LS-DYNA with the NQS queuing system.
The script contains a ‘wait loop’, which makes sure that the optimization process
stops until the solver has completely finished. This is necessary for an Optimization study where all analyses must be performed in
sequence. The wait loop can be omitted when performing a DOE study. This allows for multiple analyses to be carried
out in parallel, with the network queuing system controlling the allocation of
resources. The wait loop is checking the d3hsp file for the
string N o r m a l t e r m i n a t i o n, which signals the end of
the solution process. If another solver or queuing system is used, the script needs
to be changed accordingly. For Optimization studies,
the respective ASCII output file should be screened
for a string signaling the proper end of the solver run.
#!/bin/sh
# Set base filename for the optimization study
base=filename
# Set name of the que
que =quename
# Set environment variables for the solver
LSTC_FILE=/soft/usr/dyna/pass/v940_902
export LSTC_FILE
# Submit solution to the que
echo "cd $PWD"
echo "/soft/usr/dyna/v940_902 i=$base.bdf x=99 memory=50000000"
) | qsub -q $que
# Wait for the solver run to be finished. This can be omitted when
# running a DOE Study. Thereby allowing multiple runs to be performed
# in parallel, with the queuing system controlling the allocation of
# resources.
MSG=""
while [ "$MSG" = "" ] ; do
MSG=`grep "N o r m a l t e r m i n a t i o n" d3hsp 2>/dev/null`
sleep 30
done
# Post-process data, if necessary (Create HyperMesh result file)
/soft/net/hmdyna d3plot $base.res
# Delete data not needed
/bin/rm –f d3p* d3d*
# End of script
#Run Solvers using PBS Professional on Unix
This example script runs a solver using PBS Professional on Unix.
The sample file is set up for running LS-DYNA.
The script contains a ‘wait loop,’ which makes sure that the optimization process stops until the solver has completely finished. This is necessary for an Optimization study where all analyses must be performed in sequence. The wait loop can be omitted when performing a DOE study. This allows for multiple analyses to be carried out in parallel, with the network queuing system controlling the allocation of resources. The wait loop is checking for the existence of the .pbslock file. Its disappearance signals the end of the solution process.
#!/bin/sh
# Script to run pbs-submit from HyperStudy
cd $HOME/$2;
pbs-submit -c dyna -v 970_5434asingle_smp -m 300 -i $1
# Don't return until the job completes.
# Monitor the existence of the .pbslock file
echo "Waiting for job to complete...";
while [ -f .pbslock ]
do
continue;
done;
echo "Job completed. Returning to HyperStudy"
#################################################Run Solvers on Unix, While Study is on a Unix Mapped Drive
This example demonstrates how files on Unix can be accessed from the PC by mapping a network drive to the Unix side of the network.
In order to facilitate running HyperStudy on a PC while running a solver on Unix, HyperStudy sets a process environment variable called STUDY_UNIX_PATH. The value of this process environment variable is set to the full path of the current run directory, excluding the drive letter of the mapped drive. This environment variable keeps changing with each run.
A batch file must be created to facilitate the execution of the solver on Unix from HyperStudy running on PC.
rsh unix_mc –l user_name solver_script $HOME%STUDY_UNIX_PATH%/%1- The batch file uses the
rshcommand to log into the Unix machine and execute the solver on the iterative designs created by HyperStudy. - The variable
solver_scriptis the script to run the solver on Unix. - The batch file assumes that the mapped drive is the user’s home directory on the Unix machine, therefore, the $HOME UNIX environment variable is used in the path to the input file.
- The variable
unix_mcis the host name of the Unix computer where the solver is executed. - The variable
user_nameis a Unix login name. - In order to be able to execute the
rshinto the Unix side, the file .rhosts needs to be modified by adding the host name of the PC and your login. You can do that using vi or any other editor on Unix. The .rhosts file must have read and write permissions for the user that is specified. If a secure shell (ssh) is installed on a user’s system, the ssh can be configured with host and user keys in order to avoid password requirements. A user authentication key needs to be created on the machine running HyperStudy. This gets passed on to the Unix machine (where the solver resides) when the ssh is invoked. The solver machine needs to have a copy of the authentication key so that it can verify the user.
Run Solvers on Unix, Without a Unix Mapped Drive
This example demonstrates how to use a PC batch file and Unix shell script to run solvers on Unix, without a Unix mapped drive.
When you are running solvers on Unix, without a Unix mapped drive, the files are kept locally on the PC. Files are copied to a temporary location on the Unix machine, where the solver is executed, result files are then copied back to the study_directory on the PC where output responses are evaluated. HyperStudy sets a process environment variable called STUDY_PC_PATH, which facilitates this process. The value of this process environment variable is set to the full path of the current run directory on the PC. This environment variable changes with each run.
- When entering the values for the variables, it is important not to leave spaces after the last character or surrounding the '=' symbol.
- The file uses rcp and rsh
commands.Note: Check with your system administrator to see if these are enabled in your network.
- The batch file was created for Windows NT 4.0.
- The Unix shell script was created on IRIX 6.5.
- You want to test to see that your batch file and script are working
correctly before using HyperStudy. You will need
to replace
%STUDY_PC_PATH%in the batch file with the full path for the directory containing your test file, then at the command prompt enter: batch_filename.bat input_filename. - It is possible to adapt the Unix script to run with a queuing system.
Batch File
In the example batch file you should only need to edit the USER INPUT SECTION. However, depending on your system, you may need to alter other parts of the file.
- username
- Username for the Unix account used.
- unix_root
- Home directory on the Unix machine for the define username.
- unix_tmp_dir
- Subdirectory of the user's Unix home directory to which the input file will be written.
- unix_script
- Complete path, including file name, of the Unix shell script shown in Unix Shell Script, which is called upon to execute the solver on the Unix machine.
- UNIX_machine
- Name of the Unix machine where the solver is executed.
@echo off
::::#### USER INPUT SECTION ###########################################
:: Please Input relevant information after '=' sign on each of the
:: lines in this section.
:: For information on what information is required on each line, go to
:: the 'Interacting with your system' page of the HyperStudy manual.
set username=user1
set unix_root=/home/user1
set unix_tmp_dir=study_dir/scratch
set unix_script=/home/user1/study_dir/scripts/study1.sh
set UNIX_machine=UNIX1
::::#### END OF USER INPUT SECTION ####################################
cls
echo.
echo.
echo ---------------------------------------------------
echo User Defined Shell Parameters on PC
echo User name....................: %username%
echo UNIX home of user............: %unix_root%
echo UNIX Temp Dir................: %unix_root%/%unix_tmp_dir%
echo Unix run script..............: %unix_script%
echo Remote Unix Machine..........: %UNIX_machine%
echo.
echo.
set pc_dir=%STUDY_PC_PATH%
set input_deck=%1%
echo.
echo.
echo -------------------------------------------------------------
echo Copying input deck from PC to Unix ...
echo.
echo.
cd %pc_dir%
c:/winnt/system32/rcp.exe "%input_deck%" "%UNIX_machine%.%username%:%unix_tmp_dir%"
echo.
echo.
echo ...Done.
echo.
echo.
echo Launching Unix Shell...
echo.
echo.
c:/winnt/system32/rsh.exe %UNIX_machine% -l %username% "%unix_script% %unix_tmp_dir%/%input_deck%"
echo.
echo.
echo ...Unix Shell Done.
echo.
echo.
echo Moving all files back from unix to PC...
c:/winnt/system32/rcp.exe -b "%UNIX_machine%.%username%:%unix_tmp_dir%/*" "."
echo.
echo Deleting all files from %unix_root%/%unix_tmp_dir%...
echo.
c:/winnt/system32/rsh.exe %UNIX_machine% -l %username% "rm -f %unix_tmp_dir%/*"
echo ...Done.
echo ------------------------------------------------------------Unix Shell Script
In the example Unix Shell script you should only need to edit the USER INPUT SECTION. However, depending on your system, you may need to alter other parts of the file.
- unix_root
- User's home directory on the Unix machine.
- unix_tmp_dir
- UNIX_machine
- exe_path
- Complete path, including file name, of the solver executable to be used on the input file.
#!/bin/sh
######## USER INPUT SECTION ###########################################
# Please Input relevant information after '=' sign on each of the
# lines in this section.
# For information on what information is required on each line, go to
# the 'Interacting with your system' page of the HyperStudy manual.
UNIX_machine=UNIX1
exe_path=/soft/solver/solver.exe
######## END OF USER INPUT SECTION ####################################
echo User Defined Shell Paramters on UNIX
echo Unix home of User...................$unix_root
echo Unix Temp Dir.......................$unix_tmp_dir
echo Remote Unix Machine.................$UNIX_machine
echo Path of SOLVER Executable...........$exe_path
input_deck=$1
echo
echo
echo
echo "Stripping cntrl M's ....."
to_unix $unix_root/$input_deck $unix_root/$input_deck.tmp
mv -f $unix_root/$input_deck.tmp $unix_root/$input_deck
echo
echo
echo ...Done.
echo
echo
echo
echo "Launching SOLVER......"
echo
echo
echo "$exe_path $unix_root/$input_deck"
exit
