A DOE is a series of tests in which purposeful changes are made to the input variables
to investigate their effect upon the output responses and to get an understanding of the global behavior
of a design problem. By running a DOE, you can determine which factors are most influential on an output response.
An Optimization is a mathematical procedure used to determine the best design for a set of given constraints, by changing
the input variables in an automatic manner.
A Stochastic approach is a method of probabilistic analysis where the input variables are defined by a probability
distribution, and consequently the corresponding output responses are not a single
deterministic value, but a distribution.
