Create and Edit Parameters
Certain entities can be defined with parameters in the Entity Editor.
Create and Assign a New Parameter
Edit a Parameter
Right-click on a parameter assignment field, or click
, then select Edit
Parameter from the context menu.
- In the Edit Parameter dialog, modify the parameter's data.
- When you are finished making changes, click Close.
