Weld Line Naming Conventions
- the connection type
- the number of connected parts
- the names of the connected components
For example, a butt weld connecting the components comp1 and
comp2 will be named: hlw_B2#comp1#comp2.
Consider this weld name as another example:
hlw_T2_CustomName_#Component1#Component2.
- The weld line name should always start with
hlw_. This is the way HL-WC identifies weld components in the model. - The first letter after
hlw_will refer to the type of the weld (B, O, L and T). For example,hlw_Tis a T weld. - The number after the weld type indicates the number of components the weld
connects. For example,
T2means that the weld connects two components. CustomNamecan be any text given by you.- The final portion of the weld name is the list of components connected by weld.
The component names are to be preceded by
#. For example,#Component1#Component2#Component3.
