HyperLife
HyperLife
2021
  1. Home
  2. Additional Post-Processing Options
    Explore additional post-processing options related to the input result files.
  3. Results
    Explore the various result plotting tools for the imported result files.
  4. Contour
    Use the Contour tool to create contour plots of a model and graphically visualize the analysis results.
  5. Create and Manage Contour Plots
    Learn about creating and managing contour plots.
  • What's New
  • Get Started
  • Tutorials
  • Fatigue Analysis Overview
  • Setup Analysis
  • Evaluate
  • Manage Files and Data
  • Additional Post-Processing Options
Index
  HyperLife
2021
HyperLife
  • What's New
    View new features for HyperLife 2021.
  • Get Started
  • Tutorials
    Discover HyperLife functionality with interactive tutorials.
    Fatigue Analysis is intended for solutions to structures in a large number of loading cycles.
  • Setup Analysis
    Set up your model for analysis.
  • Evaluate
    Run the model and view results.
    • Query
      Explode the model and create derived load cases.
    • Sets
      Use the Sets tool to create, import, and export sets/groups of components (parts), elements, and nodes.
    • Display/Visualization
    • Results
      • Animate Models
        View your model in motion using animation controls.
      • Contour
        • Create and Manage Contour Plots
          • Create a Contour Plot Based on Nodal Results
          • Create a Contour Plot Based on Elemental Results (Including Corner Results)
          • Change the Display Options
          • Manage the Legend Display
          • Overlay Result Display
          • Clear Contour
          • Create Plot Style
          • Control the Display of Iso Values
          • Select a Projection Rule
          • Query Results
        • Color Band Generation
          A contour plot generates color bands on the model, based on the values found in the results file.
        • Additional Comments
        • Layers
          Layers allow you to display a contour for a specified element layer when a layer definition is available for an element.
        • Value Filter
          The Value filter available in the Contour panel allows you to specify threshold criteria for processing results only in a specific range.
        • Composites Post-processing
          Composites post-processing is enhanced in HyperLife with the reorganization of ply results as layers.
        • Cache Results
          After a contour plot has been applied in the Contour panel, the Cache feature will become active and allow you to add the currently active contour result to an internal cache.
        • Mid-side Node Elemental Results in Contour
          Mid-side nodes refers to the nodes in between the corner nodes of the 2nd order elements.
        • Post-process Abaqus Stress Results
      • Iso
        Use the Iso tool to display single iso values (iso surfaced for solids or iso line for shells) dependent on results data.
      • Vector
        Use the Vector tool to set options for a vector plot.
      • Tensor
        Use the Tensor tool to view tensor plots of stress and strain directions and magnitudes for various solvers from elemental values.
      • Edit Legend
        The Edit Legend dialog allows you to change the legend properties.
      • Graphical Editing of the Legend and Iso-slider
        You can edit the contour, vector, or tensor plot legend in the graphics area.
      • Complex Results
        Results in some analysis types come as complex numbers.
      • Computed Results
        A listing of results that are computed in HyperLife.
      • Nodal Averaging of Elemental Results
        Nodal averaging of elemental results at a node refers to the average of all the element corner results passing through that node.
      • Averaging Options
        The averaging options allow you to limit the averaging of results to only a group of elements that are considered to be bound by same feature angle or face.
    • Annotate Model Results
      Annotate model results using Notes and Measures.
    • Expression Builder
      The Expression Builder is a graphical user interface which allows user-defined data type expressions to be authored directly within HyperLife.
    • Systems
      Create your own user defined coordinate systems or select result coordinate systems.
  HyperLife
HyperLife
2021
  1. Home
  3. Results
  4. Contour
  • What's New
  • Get Started
  • Tutorials
  • Setup Analysis
  • Evaluate
Index
  • Clear Contour
  • Create Plot Style
  • Query Results
