Turn a Curve On or Off
Or
View new features for HyperGraph 2D 2021.
Discover HyperGraph 2D and HyperGraph 3D functionality with interactive tutorials.
Powerful data analysis and plotting tool for all types of CAE data.
The XY Plot toolbar is displayed when you select HyperGraph 2D from the application menu and the active window is set to the XY Plot mode,
Plot curves for multiple runs and multiple subcases for a component.
Use Build Plots to create multiple curves and plots from a single data file.
Create macros that produce curves and notes for plots.
Edit existing curves an be edited individually and new curves can be added to the current plot using the Define Curves panel.
Add horizontal and vertical datum lines to plots.
Modify a plot's curve data.
Define attributes such as line style, color, and weight, as well as symbol style and color.
Retrieves individual point data on any curve in the active window. When a point is selected, the point data is displayed on the panel.
Calculates statistics over a specified range on a curve.
Curve scaling, offsets, and axis assignments can be applied to multiple curves using the Scales, Offsets, and Axis Assignments panel.
Allows you to set default parameters for XY plots.
The Bar Chart toolbar is displayed when you select HyperGraph 2D from the application menu and the active window is set to the Bar Chart mode,
The Complex Plot toolbar is displayed when you select HyperGraph 2D from the application menu and set the active window to Complex Plot mode,
Polar plots allow you to plot complex data and are very similar to HyperGraph 2D complex plots. The polar plot toolbar is displayed when you select HyperGraph 2D from the application menu and the active window is set to the Polar Plot mode,
HyperGraph 3D offers a 3-D plotting environment that is fully integrated with HyperWorks, for managing, reviewing, and analyzing 3-D plots such as waterfall, surface, and 3-D line data.
Supported solvers in HyperGraph.
HyperGraph help for HyperWorks.
Or
